Mugabetown - Whoretownin' At It's Worst.
TAFE is so boring I'm falling asleep :/ I wanna go get my car already :(
You better be getting straight honors then...I was so bored at trade I learnt how to solve ze Rubiks cube.
Gidday Tony ma man.
Hello Mell :action-smiley-069:
Helloo!
shit day is shit
Tis Monday, I wouldn't be surprised if in another language it translated to shit day is destined to be shit lol
My uncle is a ninja at those things! He will sit there talking to me and I am so focussed on how is he holding a conversation whilst doing that I get to the point where I can't even hold a conversation, tried to teach me numerous times I always forget or give up... LOL
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
