Mugabetown - Whoretownin' At It's Worst.
Nick being near/ following your csr makes people think they have loose wheel nuts and a wheels about to fall off is how bad your car sounds up highways.
How does this work?
People reckon it sounds good #@tommis85 #me_lar
Hey guys just letting you know I won't be on the forum for a while or many events for a little while. Something happened this morning and I have to support my family. I'll talk to you guys later.
no worries Kath.
Please don't hesitate to contact me should you need anything.
Anthony
very good news indeed mate.
Xciting
Sweet so happy laps Sunday
Im not sure when it will be ready guys, its only just been started. Tuning will probably take place over the next few days. Would be a minor miracle if its ready to go for the weekend.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
