Mugabetown - Whoretownin' At It's Worst.
I am going to go over it again tomorrow, all plugs are gaped @ .8 5 are bcpr7es and 1 is a bcpr7es-11 (gaped to .8) can't find a 6th bcpr7es anywhere up here.
I will inspect the coils again tomorrow as well as the loom.
I will swap the gaped down one out first and see if that fixes it.
You may not see it. You'll need to test them.
I have the factory coils here still, I can swap them in as they has no problems and have minimal K's on them.
I will do some testing and rule them out one way or another.
That's only like 10kg nick ;)
It's 12.5kg, I drop weight on the third set on bi cepts and do more reps usually have 15kgs on there. And I would put money on most of the people here not being able to curl it 10 times even on the first set.
I've been to gyms at resorts and shit and I swear there weight messurments are wrong there 15kg bells feel like 10 etc
eggszachary :)
Found best way to stop arking put silicone around the rubber tube that connects onto the body in that little space there and fixed it
u talkin bout a car or putting fake tits on yourself?
Seriously Nick, your talent is wasted in Gatton. You should definitely look into NIDA :yes:http://www.nida.edu.au/
Yer, mayb... I wouldn't call it talent as much as professional smart ass/shit stirer :P
I curl 16 with dumbells and 30 with barbells
I'm guessing your laughing at the part where I don't keep up with your capabilities? Haha
Well... if you say you curl reps at 16kg (which I'm not sure how you even obtained that weight [very odd number]) then well good for u.
If your forms good then that's a big achievement and something to be proud of.
just my
Gyms different and goes up weights in intervals of 2kg haha
Edited by Matty95
You forgot the weight of the bar
I can do that 10 times on every set, but not with my arms or legs lol
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
