Mugabetown - Whoretownin' At It's Worst.
I am going to go over it again tomorrow, all plugs are gaped @ .8 5 are bcpr7es and 1 is a bcpr7es-11 (gaped to .8) can't find a 6th bcpr7es anywhere up here.
I will inspect the coils again tomorrow as well as the loom.
I will swap the gaped down one out first and see if that fixes it.
You may not see it. You'll need to test them.
I have the factory coils here still, I can swap them in as they has no problems and have minimal K's on them.
I will do some testing and rule them out one way or another.
That's only like 10kg nick ;)
It's 12.5kg, I drop weight on the third set on bi cepts and do more reps usually have 15kgs on there. And I would put money on most of the people here not being able to curl it 10 times even on the first set.
I've been to gyms at resorts and shit and I swear there weight messurments are wrong there 15kg bells feel like 10 etc
eggszachary :)
Found best way to stop arking put silicone around the rubber tube that connects onto the body in that little space there and fixed it
u talkin bout a car or putting fake tits on yourself?
Seriously Nick, your talent is wasted in Gatton. You should definitely look into NIDA :yes:http://www.nida.edu.au/
Yer, mayb... I wouldn't call it talent as much as professional smart ass/shit stirer :P
I curl 16 with dumbells and 30 with barbells
I'm guessing your laughing at the part where I don't keep up with your capabilities? Haha
Well... if you say you curl reps at 16kg (which I'm not sure how you even obtained that weight [very odd number]) then well good for u.
If your forms good then that's a big achievement and something to be proud of.
just my
Gyms different and goes up weights in intervals of 2kg haha
Edited by Matty95
You forgot the weight of the bar
I can do that 10 times on every set, but not with my arms or legs lol
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
