Mugabetown - Whoretownin' At It's Worst.
I am going to go over it again tomorrow, all plugs are gaped @ .8 5 are bcpr7es and 1 is a bcpr7es-11 (gaped to .8) can't find a 6th bcpr7es anywhere up here.
I will inspect the coils again tomorrow as well as the loom.
I will swap the gaped down one out first and see if that fixes it.
You may not see it. You'll need to test them.
I have the factory coils here still, I can swap them in as they has no problems and have minimal K's on them.
I will do some testing and rule them out one way or another.
That's only like 10kg nick ;)
It's 12.5kg, I drop weight on the third set on bi cepts and do more reps usually have 15kgs on there. And I would put money on most of the people here not being able to curl it 10 times even on the first set.
I've been to gyms at resorts and shit and I swear there weight messurments are wrong there 15kg bells feel like 10 etc
eggszachary :)
Found best way to stop arking put silicone around the rubber tube that connects onto the body in that little space there and fixed it
u talkin bout a car or putting fake tits on yourself?
Seriously Nick, your talent is wasted in Gatton. You should definitely look into NIDA :yes:http://www.nida.edu.au/
Yer, mayb... I wouldn't call it talent as much as professional smart ass/shit stirer :P
I curl 16 with dumbells and 30 with barbells
I'm guessing your laughing at the part where I don't keep up with your capabilities? Haha
Well... if you say you curl reps at 16kg (which I'm not sure how you even obtained that weight [very odd number]) then well good for u.
If your forms good then that's a big achievement and something to be proud of.
just my
Gyms different and goes up weights in intervals of 2kg haha
Edited by Matty95
You forgot the weight of the bar
I can do that 10 times on every set, but not with my arms or legs lol
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
