Mugabetown - Whoretownin' At It's Worst.
Who wants to buy some parts? Particular interest would be in the big f off brakes I guess... And 2 sets of coilovers that fit r32 gtr
z32 afm's and z32 ecu's with nistune installed.
big, serious brakes. Stoptechs, 2 piece rotors, pads, braided lines.
Rears are AP racing, nearly same as the stoptechs. But for the rear.
Edited by MagicMikeZ32
QUEENSLANDERS! I NEED YOUR HELP!
is anyone near jacobs well and would pick up some car parts for me and post them to victoria? its a tiny exhaus manifold and some headlight protectors.
please help me qld. your my only hope.
you really think any of us Qlders are really gonna help you?
Seriously Paulie...................................dafuq mang????
kiddin.......
Where abouts in Jacobs Wells and has the parts been paid for or is the gansta B&E situation?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
