Mugabetown - Whoretownin' At It's Worst.
A real pissing contest would be who has the fattest wallet. ;)
Not the fattest, but it is pierre cardin if that matters?
Got a hole in the coinage bit tho. That keeps it nice and skinny...
It looked rough TBH :rofl:
So you don't actually believe function is form then, because this works and does so on a few cars now. I will get some professional photos and make up a web site how it was ROOOOOOOLY hard to make and that no one else has done any research on it and charge $1000 for a metal disc with slots cut in it.
You also have a hoist in the shed, two zeds a lovely wife, awesome house and two adorable puppies. Your cat scares me.
3 zeds ;)
And 2 cats. Which one scares you? The big ginger one?
Ginger anythings scare everyone.
Because female.
:P
Least I don't drive like a girl :)
Lol!
Yeah I was like nawwwww damnit!
Ooooh and I have a fat wallet because it's always full of coinage!!!
And cats are awesome...
For the sake of Mel, Mike, Titan and Ants. I'll change out of the DPU :)
One more... you say it functions, which doesn't mean poo. Where's the Harmonic balancer?
