Mugabetown - Whoretownin' At It's Worst.
preparing for my first xmas alone in 23 years woo...
ill probably get pissed and watch porn :P
Mr ants. is there any huge drama removing the cam cover?? or do i need to remove the CAS ?
if so help! :P
the cam covers no. The timing belt /cam gear covers yes.
Because. You will need a timing light to reset the timing exactly to what it was before.
Lazy bro. It's very cold and no sunlight.
Just the way I like it ;)
So when we both get drunk and I throw u in the freezer for lulz you'll know why :P
But yer, I'm watching rbt I love this show
Ohhh crap!
So do I need to brace myself for this one lol?
No, childhood friend that I lost my vs to.... Went out to her place on the weekend and hooked up, haveing them feels bro
Did come up with something very dirty to reply but decided best not too haha.
Well that's not fun :P I just couldn't think of a better way to ask the question haha
Morning all
lol....I'd be non too impressed if my car drank that much.
My clutch too is in need of replacement, Havent tackled that yet. But the timing belt is relatively simple, as long as you have time and some mechanical knowledge......oh and patience...lots of patience. hope that helps :)
Because skids?
Yeah it's the patience I'm gonna struggle with haha :D Nah, I love the hands on mechanic work, I've been building her for almost three years. Just gotta remember she deserves it :P
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
