Mugabetown - Whoretownin' At It's Worst.
I'm not sure what happened last night but somewhere between "hey I kinda feel like a gin" and "f**k I feel sick as", a small homosexual leprechaun seems to of hacked phone... This is what I awoke to in my recently downloaded list :/
*i do vaguely remember dancing around with a feather boa
My week so far has consisted of sleep, boating, beach, sleep, drinking and the of game or 2 of pool
And watching all the little blonde Gold Coast wiminz go jelly over my zorst note for some reason
getting in before someone comments about you taking the 33 out on the water.
I think R33 resembles more like inflatable dinghies rather than an actual boat........but that is only my opinion
Had to leave work at 6:15 today. Phone was running low on juice and it wasn't charging off my laptop... anyone else having issues with battery life on galaxy devices?
It's not galaxy devices it's 4G. I turned my 4G off and the battery lasts much longer.
Battery dr helped me a lot. A few deep cycle charges and I can go nuts on it all day
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
