Mugabetown - Whoretownin' At It's Worst.
Haha. I get a mild case of OCD too if i have a desk etc... Weird.
My love of silence got that extreme that i used to work with a friend that sat at the desk next to me. Not Barrier or anything blocking our view at each other, however it got to a point where we would email each other in coversation instead of looking a meter to the side and actually asking lol
I don't mind a bit of banter around the office and background noise helps. in our industry, it's meant to be loud with people on the phones etc however when it's mindless BS because our junior can't remember what she had for lunch the previous day let alone where a candidate is currently working, pisses me off.
Eg: Yesterday, the boss came in and we were running a brainstorming sesh for this new campaign. He was asking all of us about candidates that we're working with. I could tell you where they worked, how long for and where they lived without looking. The other senior consultant was close. Our junior couldn't even remember surnames accurately! WTF?!!? So when she asks me the same question 3x in a day, I crack the shits.
You really were born in England weren't you? :P
  • Like 1
Back in Bris. Got home just before midnight last night. Plane from Mt Isa was late leaving, but I upgraded to business class, assuming that we would be doing laps of Bris with all the rain.
Chivas ftw, didn't care how late the plane was haha
Also, have all paperwork with me to go get some shiny new rego plates today!
Agree, Mindless conversation is annoying. Also another thing that grinds me is unnecessarily loud phone voices in an office.
Just unnecessarily loud voices In General Scott haha like people that have to talk rediculously loud when they are right next to you, fair enough when there is a lot of background noise and you are gonna struggle to hear but when there isn't and they are like yelling.
we have one of those, he also puts his phone on speaker so its double loud voice! Last week I had on noise cancelling bud type ear phones and proper industrial noice cancelling ear muffs and I could still hear him when there was a break in the music
He's calling you a pom bloody smash 'im
He gets it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
