Mugabetown - Whoretownin' At It's Worst.
Morning had a big night on the car lastnight
Swapped all the belts over and ran all the wiring for sub and lights and stuff
Swapped over the back seats and front seats also fought with some plugs and found the new car has no 2nd o2 sensor so looks like more money on the exhaust
The second sensor in the exhaust is just a cat temperature warning sensor I think. Doesn't really do anything other than give you a dash light if it gets hot.
Pretty much, it lets you know when the cat has no internals left.
It has nothing to do with the ecu so don't worry about it Zac.
Can be an indicator of exhaust temp too high also (obviously). In which case, something isn't quite right.
Also, how goes the new zorst Scotty?
yeah, every vehicle has a unit that uses Iridium sat's to give a constant feed of speed (GPS measured), acceleration, braking etc. You key in with a unique tag each time you start the vehicle so they know who was driving. Main idea is to detect rollovers etc but in reality its mostly used for speeding tracking
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
