Mugabetown - Whoretownin' At It's Worst.
I thought spots were taken already?
I want to wait a little Grego
Sprints would be awesome but would be a huge step for me and I don't want to jeopardise the car nor anybody else's car because lack / no racing experience
Plus I need to by helmet and whatever else
Baby steps first mate
Typical french man surrendering at the first sign of anything. Talking to you after the cruise you said you would be there.
Sounds like a poor excuse to me :P $100 motorbike helmet
This guy knows poor excuses, also makes a good point that helmets aren't expensive.
Sprints at qr is the place to learn
100% this.
probably. Think anyone can drive better than me
Who really cares, as long as your out there having fun and getting some enjoyment from your car you've spent all this time and money on.
It also gives you a base line to start working from when you start upgrading other parts of the car e.g. hicas locked out, suspension/diff swap etc.
  • Like 1
100% this.
All of this, you have to start somewhere and QR is the best place.
100% this.
I am aware of all of this ^ except for the 'typical Frenchmen surrendering' part I never give up nor surrender to anyone!
There will be plenty of other opportunities to learn with QLD SAU
So what's the real reason for the rush regarding this event?
So what's the true reason behind rush?
We want to see the ant eater on track giving it to some Evos.
Obviously you missed this part
Clearly surrendering
that doesn't answer my question Grego
Also IIRC I'm pretty certain I mentioned to you I wanted to replace my suspension first you seem to have obviously missed that part.
It's pretty simple. I don't feel ready.
If I don't feel ready it's because I'm not ready.
I want to build my confidence slowly and safely.
Not jeopardise everything in one hit because being pushed into something I am not ready for.
I can't be anymore clearer than that and will not be participating to this track day in June.
I will however be happy to spectate to see how it all unfolds
Give me time guys that is all
Just the tip then?
(Out of context phrasing much :rofl: )
Edited by pretX
So bored training to become a lifeguard... When there could be so much more I could be doing
at least you are doing something to help and protect swimmers from drowning
I respect that
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
