Mugabetown - Whoretownin' At It's Worst.
I thought spots were taken already?
I want to wait a little Grego
Sprints would be awesome but would be a huge step for me and I don't want to jeopardise the car nor anybody else's car because lack / no racing experience
Plus I need to by helmet and whatever else
Baby steps first mate
Typical french man surrendering at the first sign of anything. Talking to you after the cruise you said you would be there.
Sounds like a poor excuse to me :P $100 motorbike helmet
This guy knows poor excuses, also makes a good point that helmets aren't expensive.
Sprints at qr is the place to learn
100% this.
probably. Think anyone can drive better than me
Who really cares, as long as your out there having fun and getting some enjoyment from your car you've spent all this time and money on.
It also gives you a base line to start working from when you start upgrading other parts of the car e.g. hicas locked out, suspension/diff swap etc.
  • Like 1
100% this.
All of this, you have to start somewhere and QR is the best place.
100% this.
I am aware of all of this ^ except for the 'typical Frenchmen surrendering' part I never give up nor surrender to anyone!
There will be plenty of other opportunities to learn with QLD SAU
So what's the real reason for the rush regarding this event?
So what's the true reason behind rush?
We want to see the ant eater on track giving it to some Evos.
Obviously you missed this part
Clearly surrendering
that doesn't answer my question Grego
Also IIRC I'm pretty certain I mentioned to you I wanted to replace my suspension first you seem to have obviously missed that part.
It's pretty simple. I don't feel ready.
If I don't feel ready it's because I'm not ready.
I want to build my confidence slowly and safely.
Not jeopardise everything in one hit because being pushed into something I am not ready for.
I can't be anymore clearer than that and will not be participating to this track day in June.
I will however be happy to spectate to see how it all unfolds
Give me time guys that is all
Just the tip then?
(Out of context phrasing much :rofl: )
Edited by pretX
So bored training to become a lifeguard... When there could be so much more I could be doing
at least you are doing something to help and protect swimmers from drowning
I respect that
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
