Mugabetown - Whoretownin' At It's Worst.
all of this ^
But I do have ship loads of work to do so full week is needed
I am a bit the same. 2 massive inspections on Wednesday and Thursday and heaps of stuff due should make for a fast week
Uggggh full week this week :( worst Monday ever.
Yes... It's fck this shit o'clock... Actually it was that at 8:00am and thats when I was meant to start but was already at work having a shit day...
but the money is good....
stop messing around with an R32 GTR then and just buy an R35 GTR
No modding necessary - well actually yes there would be in the future, however....
plenty of power and handling comes direct from factory to keep you satisfied for quiet some time and has the looks to go with it.
Might have spent 70k total on the 32 in 2-3 years time, and for that it'll have a brand new engine. Better than a flogged R35 for over 100k... Also personally I think they look crap.
Will still be a dirty 32 tho ;)
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
