Mugabetown - Whoretownin' At It's Worst.
Football was awesome last night. Great way to finish a season. The atmosphere at "soccer" games will never be beat.
Tony I stand in the middle of the den behind the goal. Singing away with being stupid..
Needless to say I have no voice left this morning
Is the no voice left from singing? Or the more likely of soccer activities lol
Man, I'm f**king wrecked this morning. Met up with a few of the bosses mates and didn't think they would drink that much. Man was I wrong! Someone pulled out shots and the boss was saying that he isn't allowed to have shots so I had to drink them!! Soooooo wrecked this morning.
Love this cold erather
Took the Ant-eater out yesterday, she likes the cold too :)
I love it too. Summer does not make me happy! I tried to take my car out over the weekend, dead battery. Won't turn the car over and the charger claims it is full <_<. I really need a multimeter actually because perhaps I blew a fuse.
Morning Ants. Weather just became really cold really quick down here. Omfg it's going to be a cold winter :(
Morning. Yeah, I was thinking the same re: winter maybe colder this year than last year
drinking heavily the nite before work day = much fail
perhaps borrow a multi meter to test that out.
Sometimes it's just simply the battery that plays up or is le dead :(
Breatho every morning on site. At 6am. You want to make sure your only hung over.
When my mate got a job at one of the big mining companies, we went out to celebrate once he started. He had accidentally left his bag in the office and was scared to go in and get it - after hours on a Friday night. Find it a little crazy that head offices are dry sites.
They have to be dry, otherwise it's discrimination. You can't have one rule for the rank and file and another for the engineers/execs at head office when it comes to things like drug and alcohol testing.
Not necessarily. If it was all personnel on site have to be dry, then you could get around it. I get where you're coming from though.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
