Mugabetown - Whoretownin' At It's Worst.
Buy expensive cry once, buy cheap cry daily
Honestly, I was. However Someone had this one so I thought why not, 350 bucks.
that being said, i'm dubious of the plazaman ones. The one pictured on their site doesn't look like it'd fit on the mounts.
Probably cools the intake charge and doesn't leak... :P
I think the factory one does that as well.
So calling the phone number on their website and asking them if the GTR intercooler was a bolt up job never crossed your mind?
but isn't the factory FMIC limited to 300rwkw and looses efficiency after that?
I only started worrying about their fit after having issues with this one today. By the time i'd got back in and fnished packing everything up it was after 4, so i figured i'd give them a call in the morning... :yucky:
My Hybrid one does a better job...
Good for you and your car
If the car doesn't go to the track or drag strip when do you get the chance to use those 300+ killawasps?
  • Like 1
Just out of curiosity, do drag strips allow intercooler sprays?
Straight from the andra manual
4.6.1 Intercoolers
Must be securely mounted with all hoses securely clamped. No restriction,
apart from location, on air-to-air units. Air-to-liquid are limited to water
and/or water ice ONLY and must be sealed to prevent fluid dropping
on to track surface. Dry ice permitted on its own but housing must be
vented to atmosphere to prevent pressurizing of system. Intercoolers
must be located outside of the driver’s compartment or contained in a
commercially manufactured ballistic containment device and fitted with
a relief valve / burst panel vented outside the driver’s compartment to the
atmosphere.
  • Like 1
I try to use it every time I drive the GTR.
It's fairly easy to do especially those long M1 on-ramps we have here on the GC
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
