Mugabetown - Whoretownin' At It's Worst.
Morning all...
I had Body Effects yesterday morning aaand yesterday evening I had Beta-Cret 2.0... I used to use Oxy-Elite, Jack 3D and Albutrex (All original blends) then they were banned and the new versions aren't as potent...
OI! NARK! I said Robin goes faster than Zeke in the chat, why your sig say Mike said it? :glare:
Delayed responses...
Feeling pretty seedy today. Definitely too old to be getting home at 8/9am :S
I felt great, had a 5hr nap and was good to go again :bunny:
Woohoo! Go Ricciardo! As McFly kindly pointed out, getting too old for this shit.
Twas a good finish, you too old? I am older than you are!!! Man up buddy!!!
Suzuka is on in the October long weekend, it's a 4pm start not a 4am :banana:
In! Seriously, should organise something for this...
Morning all...
http://www.bulknutrients.com.au/buy/pre-workout-101/PW101 ;)
I tried that previously wasn't as amazing as people said it was for me. Mind you I used to drink 6-8+ large redbulls a day before I had to stop because I was addicted to them and got angry when I didn't have one...
I had about 2-3 hours sleep... I can never sleep during the day :(
Went to bed at about 8pm that night though and slept like a log!
Keen.
many shift, much jdm, wow!
Good knob... have one in the wedge and the pinny. Half tempted to get one for the navlux too
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
