Mugabetown - Whoretownin' At It's Worst.
Morning all... RBT on the way to work then one of the work vehicles has broken down so cancelling appointments all before my normal start time! Hopefully that's Monday getting it out of it's system early on!
Ahhh Mel. All the luck in the world there......not
Yeah, Monday and I don't get along well at all! I was saying to Martin yesterday that I haven't had an RBT for a whilst, was actually surprised it didn't happen yesterday with all the police we saw. At least it wasn't the "stalker" officer that says "Hey Melissa gotta check your licence" as soon as he gets to the window because he has pulled me over that often for RBT's that he knows who I am!
You don't go around corners anyway do you? :P
No but ball joints are f**ked out in the back of my hubs so when I get new ones a may aswell do this, or just a lock bar :/
Hence want to know a price difference and how much of a karnt the ball joints are to get out?
lol - constable oink
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
