Mugabetown - Whoretownin' At It's Worst.
Woke up this morning and my back is killing me. It's actually been good 2 months almost pain free and today I can barely move. f**king back pain.
thats no good Tony
Go see a chiropractor perhaps?
And ask mike how much for his price in the other kit
And the rear hicas joints are a kent to do. But I has special tool to make it easier :)
$100, opened but unused due to writing his car off, normally go for around $200-$250
So new for new about the same. It them comes down to which system have you heard more issues with
Like I'm happy with the lock bar and it works well and looks somewhat stock so that's a plus
Then again so would a black delete kit
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
