Mugabetown - Whoretownin' At It's Worst.
Actually, that's not really true... If it is working correctly, you don't really notice it.
Something something if it ain't broke something
Not sure if Mel's is working properly or not but I sure noticed it.
Turn in to corner...
Then correct for hicas
Straighten up out of corner...
So it might just be it reacts a little slow to what you are doing... or it might be stuffed. Haven't driven enough HICAS cars to be sure.
Either way, it needs to go!
Noticed there's a sprint day on on the 13th. I will be in town...
Aww heck i'll enter it.
edit: sprint day page!
I think Dave is taking his pinny out to that, so I might head out for a look
Sounds about right for 18 year old HICAS. Thats why I had to pull mine out.
Pinky just wanted a go at steering haha! Will attempt to get rid of it once I get the lock bar from Mike... Before Happy laps tho, Sooo very soon... Probably means won't be going to watch sprints because I'll be trying not to break too much whilst getting rid of HICAS that weekend!
bah youl be right. Just get Grego to supervise
Hahaha! I don't know if he wants to supervise me when tools are involved, I don't have a very good track record at not hurting myself! :-)
Not too hard, I did it by myself.
Then you can do an eye alignment.
Lol, yeah... I think the place next to work does alignments so I'll hopefully be able to just drop it in when I go to work and pick it up when I leave.
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
