Mugabetown - Whoretownin' At It's Worst.
Actually, that's not really true... If it is working correctly, you don't really notice it.
Something something if it ain't broke something
Not sure if Mel's is working properly or not but I sure noticed it.
Turn in to corner...
Then correct for hicas
Straighten up out of corner...
So it might just be it reacts a little slow to what you are doing... or it might be stuffed. Haven't driven enough HICAS cars to be sure.
Either way, it needs to go!
Noticed there's a sprint day on on the 13th. I will be in town...
Aww heck i'll enter it.
edit: sprint day page!
I think Dave is taking his pinny out to that, so I might head out for a look
Sounds about right for 18 year old HICAS. Thats why I had to pull mine out.
Pinky just wanted a go at steering haha! Will attempt to get rid of it once I get the lock bar from Mike... Before Happy laps tho, Sooo very soon... Probably means won't be going to watch sprints because I'll be trying not to break too much whilst getting rid of HICAS that weekend!
bah youl be right. Just get Grego to supervise
Hahaha! I don't know if he wants to supervise me when tools are involved, I don't have a very good track record at not hurting myself! :-)
Not too hard, I did it by myself.
Then you can do an eye alignment.
Lol, yeah... I think the place next to work does alignments so I'll hopefully be able to just drop it in when I go to work and pick it up when I leave.
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
