Mugabetown - Whoretownin' At It's Worst.
For larger turbos they make more difference than smaller IMO. I doubt you could even tell.
Just like anything, work out what you want from a particular setup, and then research.
And do it once, do it right. Much cheaper in the long run ;)
Well the highflow 34 turbo will do exactly what I want, the only difference is I have a place that will do it with ball bearings for $1350 or one from Hypergear with a thrust bearing for $860.
thrust bearing is poor in comparison to ball bearings you want to know why?????
not just because ball bearing actually spool faster than journal bearings................
but....................
because......................
it reduces the oil flow required for lubraction and it increases the longevity / durability of the turbo compared to journal bearings
Might as well have gone a gt2867 brand new if you pay that much + cost of 34 turbo
A good hi flow option from hypergear that will bolt to stock manifold and dump can make more power than a gt28
This is what I was thinking, I can get a 34 turbo and highflow it for about $1000.
+1 the small frame garrets are a pain in the ass to bolt up to an Rb and they probably have no more power potential. High flows are pretty under rated
Clint was running a ss1pu early model and made around 350hp from memory on pump98 fuel.. Hi flowed r34 turbo + e85 should see easy power with stock response. I'm my opinion it would make a perfect street daily.
remove and purchase -9 Pete or T51r or both lol
But effort.
Are they a direct fit to the stock manifold and dump Pete?
I thought so?
Again, i was comparing a hihg flowed ball baring turbo to it, not a hypergear journal bearing one.
More making a point at what you're paying for if you go for a brand new one.
But effort.
I thought so?
Our "Journal bearing one", is more responsive then your ball bearing one, and last 10x longer.
Yeah I agree Pete, I'm very much leaving towards the hypergear. I want to get an ecu and injectors capable of running e85 but running and running in pump 98 until I either get a second car or have e85 scalable locally.
nah man. Clint was actually making 400hp at the treads
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
