Mugabetown - Whoretownin' At It's Worst.
Nismo fuel pumps are only 275lph or something silly. Sure they bolt in but thats about it. 450lph walbro pump will also cost ~150 bucks less IIRC. If the R33gtst fuel pump mount setup is similar to the R32gtst it's a peice of piss to modify it to fit, though getting to the tank may be harder due to 33's being less likely to combust in a rear end accident.
You could probably easily go smaller injectors (720cc?) and shave off a hundred bucks. Also make sure you buy side feed injectors to suite your fuel rail, with the right size holes etc.
Really need a FPR? Making 300kw's here without one, but maybe there's different stuff on the GTR fuel system?
I wouldn't double the tuning, maybe add only 50%, for flex. You're basically getting two tunes in there. That's assuming you have no issues however, which can quickly add up unfortunately. I mean, best case, just a 98 tune, 500 bucks maybe. Worst case, things to wrong, flex tune, 2000 bucks isn't out of the question, so be ware.
you're also just missing little stuff. Turbo gaskets, new studs, fittings for Ethanol sensor and the like can add up to a few hundred bucks
You'll need to figure out how you're going to get the car to the tuner aswell, Everything you need to do is easy enough to DIY at home (and... satisfying to do, i'd recommend it), but with bigger injectors the car will be undrivable unless you can get the tune adjusted for the injectors. Not sure how easy haltec is to modify
Not compatible? So Walbro over Bosch 040?
If you say so. You've done it recently.
yeah, the Walbro pump is E85 ready and as Pete said flows more than nismo pumps.
It can be fitted in tank too (just like mine)
Yeah, budget for at minimum 2k in tuning costs with eflex
R33 fuel tank is completely different to R32, just FYI.
Not sure how simple it is to mount a walbro/040 in tank in an R33
well as long is its not mounted to the tank floor it'd be easy enough :woot:
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
