Mugabetown - Whoretownin' At It's Worst.
Nismo fuel pumps are only 275lph or something silly. Sure they bolt in but thats about it. 450lph walbro pump will also cost ~150 bucks less IIRC. If the R33gtst fuel pump mount setup is similar to the R32gtst it's a peice of piss to modify it to fit, though getting to the tank may be harder due to 33's being less likely to combust in a rear end accident.
You could probably easily go smaller injectors (720cc?) and shave off a hundred bucks. Also make sure you buy side feed injectors to suite your fuel rail, with the right size holes etc.
Really need a FPR? Making 300kw's here without one, but maybe there's different stuff on the GTR fuel system?
I wouldn't double the tuning, maybe add only 50%, for flex. You're basically getting two tunes in there. That's assuming you have no issues however, which can quickly add up unfortunately. I mean, best case, just a 98 tune, 500 bucks maybe. Worst case, things to wrong, flex tune, 2000 bucks isn't out of the question, so be ware.
you're also just missing little stuff. Turbo gaskets, new studs, fittings for Ethanol sensor and the like can add up to a few hundred bucks
You'll need to figure out how you're going to get the car to the tuner aswell, Everything you need to do is easy enough to DIY at home (and... satisfying to do, i'd recommend it), but with bigger injectors the car will be undrivable unless you can get the tune adjusted for the injectors. Not sure how easy haltec is to modify
Not compatible? So Walbro over Bosch 040?
If you say so. You've done it recently.
yeah, the Walbro pump is E85 ready and as Pete said flows more than nismo pumps.
It can be fitted in tank too (just like mine)
Yeah, budget for at minimum 2k in tuning costs with eflex
R33 fuel tank is completely different to R32, just FYI.
Not sure how simple it is to mount a walbro/040 in tank in an R33
well as long is its not mounted to the tank floor it'd be easy enough :woot:
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
    • Yeah it is wild how much wider the Yokohama A050 in 255/40R17  vs Yokohama AD09 in 255/40R17 sits on the 17x9 +22 considering its even from the same brand and adjacent product family
    • Would love to see some examples of WMI making the same as E85. Only thing I've ever found is this one.  Which suggests WMI is not worth much at all.
    • And now the washer bottle looks like an orphan. You're going to have to spend money on a wrinkle black painted fabbed ally one of those. Oh, and the brake MC res. That won't look any good after you've gotten rid of the washer bottle. You going to need to go back to work to keep up with this?
