Mugabetown - Whoretownin' At It's Worst.
Nismo fuel pumps are only 275lph or something silly. Sure they bolt in but thats about it. 450lph walbro pump will also cost ~150 bucks less IIRC. If the R33gtst fuel pump mount setup is similar to the R32gtst it's a peice of piss to modify it to fit, though getting to the tank may be harder due to 33's being less likely to combust in a rear end accident.
You could probably easily go smaller injectors (720cc?) and shave off a hundred bucks. Also make sure you buy side feed injectors to suite your fuel rail, with the right size holes etc.
Really need a FPR? Making 300kw's here without one, but maybe there's different stuff on the GTR fuel system?
I wouldn't double the tuning, maybe add only 50%, for flex. You're basically getting two tunes in there. That's assuming you have no issues however, which can quickly add up unfortunately. I mean, best case, just a 98 tune, 500 bucks maybe. Worst case, things to wrong, flex tune, 2000 bucks isn't out of the question, so be ware.
you're also just missing little stuff. Turbo gaskets, new studs, fittings for Ethanol sensor and the like can add up to a few hundred bucks
You'll need to figure out how you're going to get the car to the tuner aswell, Everything you need to do is easy enough to DIY at home (and... satisfying to do, i'd recommend it), but with bigger injectors the car will be undrivable unless you can get the tune adjusted for the injectors. Not sure how easy haltec is to modify
Not compatible? So Walbro over Bosch 040?
If you say so. You've done it recently.
yeah, the Walbro pump is E85 ready and as Pete said flows more than nismo pumps.
It can be fitted in tank too (just like mine)
Yeah, budget for at minimum 2k in tuning costs with eflex
R33 fuel tank is completely different to R32, just FYI.
Not sure how simple it is to mount a walbro/040 in tank in an R33
well as long is its not mounted to the tank floor it'd be easy enough :woot:
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
