Mugabetown - Whoretownin' At It's Worst.
Replacing some of toothless' fluids in preparation for laps of happy on Sunday. Keen!
Hopefully there's no rain, keen to see the line up between Toothless and The SS :devil:
why is it toothless? do you have a dragon or something??
I can't remember who exactly named it toothless first but when I bought it the headlights were very cloudy, oxidised and yellowly green. Like the eyes of the dragon toothless from "how to train your dragon"
...I'm still working on making it shoot purple flames...
Dislike today... Tried to do the right thing by coming in for half day to get stuff done and so manager could run errands, was meant to be gone at 12:30, still here because the manager isn't back. And it's f**king raining so have to walk my sick ass through the rain to pick up my car when I can actually go. Should have stayed in bed :-(
see if you worked me - I would of told you to stay at home
They told me to go home... I just had to wait till they were back... But yay home finally and didn't have to pay for my wheel alignment and my number plates arrived...
pink plates aiiight?
Not talking about custom plates nate, just slimline of my normal off the shelf plates. But I don't think "they wont fit the car all of a sudden after 4 years" will be enough reason for qld transport to give me a replacement slimline front plate
oh really? my front slimline plate has the edge broken (been like that for at least 4 years) can I request for it to be replaced at no cost?
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
