Mugabetown - Whoretownin' At It's Worst.
Ha! Nismo fuel pump with E85? I'd go for Walbro 450 ltr/pm
Tuning $1,000???? Double it
fark,what do they do to cost that much,in the wrong business by the looks of it.
I believe it's an hourly charge, it takes quite a few hours to tune from scratch. A lot of the cost is because dynos are f**king expensive to buy.
this ^ + also dyno maintenance
Just did my tax return online...
Pretty sure that something is messed up. I could buy a good R33 with the return i'd be getting.
So i'm not submitting it yet because i'd eventually have to repay the government money.
I think my employer may have messed up my group cert, my yearly income seems way to low.
How long have you been on site?
We were, Scott is a power whore so he likes to use archaic outdated measurements :P
HP is a bigger number so sounds faster lol...
lol although Scottie's machine makes the numbers sound good in either measurements
Mine only makes 340kw's at the moment. Hopefully soon I'll be back over 450kw's
10 months or near enough
My income is too low, but I also figured out the majority reason why the return was so big. Stupid MyTax doesn't let you put your HECS calculations in. Dam. No spare good R33 this year.
myTax automatically accounts for any HECS/HELP - what the estimate says should also be what you are getting back refund wise. Unless you're a shifty bugger
I didn't see anything about it there ants.
anyway, a few quick back of the envelope calculations (don't have pay slips here with me), I have 2 group certs, one for pay on old system and one for pay on new system. The one for the old system is underreporting my income by about $12000, but not my tax withheld. That explains some of the wonkyness.
gotta hand it to the company they really screwed up the pay system transfer something epic now.
yeah I think you should check with the payroll dept.
HECS/HELP IS incorporated in the estimate but they don't give you a breakdown which shits me
We are transitioning to a new payroll system in 2 weeks, I am scared now.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
