Mugabetown - Whoretownin' At It's Worst.
no. Just like everyone else you need to earn it.......unless I win 5M dorras then I help you if you are a good boy
I do earn it, I just have other things I need to pay for first :(
Dam brakes. To many options, can't figure out what i want to get.
R33 brakes bolt straight on.
Bigger ones are probably only a bit more expensive if i just get fronts.
But i might want to get even bigger ones later, in that case the 33 brakes would be easier to move on.
Or i could go straight to even bigger ones but i'd need to get 18's...
In which case do i get TE37s again or something else.
Argh decisions.
Argh decisions.
Easy decision: buy the Leopard :P
  • Like 2
Argh decisions.
what are you on about Pete?
Your 17in TE37's will have more than enough room for a big brake kit
Also new big brake kits cost a lot more than R33 GTR Brembos Pete
40 minute sessions at wakefield, and my GTR Brembos never smoked... Just sayin! They have become fairly underrated over the last few years. Though I have never paid 1800 bucks for them. My first set of fronts cost 800 with dba 5000 rotors and my full set cost 1300 with dba 5000 front rotors.
Some between 4 and now Mel :(
Now I'm going to get up and drive to Beacmere to meet a client I know and help them put all their work on a cloud
I'm actually really looking forward to this :)
  • Like 1
Have you moved completely to xero in house?
Front D2 kit is about ~2K,
R33 all round is 1800 bucks by the time you get them rebuilt etc
Get real brakes. D2 are rubbish.
Do it once, do it right. Cheaper in the long run Pete.
If R33 Brembos bolt straight on, that means all Z32 kits will bolt straight on.
Check out here:
http://www.conceptzperformance.com/Cart/items.php?Car_Type=300&car_cat=Brakes&CA=24&UID=20140720194920203.9.185.243
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
