Mugabetown - Whoretownin' At It's Worst.
I'm a fan of do it right do it once... But what is right for me o do not know.
Braided lines, new rotors and good pads would likely be up to weekend drives and occasional track work. You need to decide your budget then go from there. If you are happy to spend 4k you can't go wrong with the high end stuff. But much lower spending will also get you results.
I have never met one more angst filled about mods! Lol
Work had for my money, don't want to waste it.
Haven't had a good run of luck with stuff for the car so far either, hence making double sure before I buy anything else.
Pads and braided lines won't make up for the 32 Sumitomos though i don't think, so i'd say i'd need to get something bigger for sure.
So, for research's sake, which companies make good quality brake kits, and which should one stay away from?
Right
So all those people who have D2/G4/K Sport brakes on their cars and say they are good are talking out their ass then?
In a word... yes.
Placebo is a wonderful thing. It makes justifying paying 2k for china crap easy ;)
Are they an upgrade over stock? Sure. Most kits are.
I would go brembo, ap racing, stoptech or something else that comes oem on something that's bigger.
Go with something made by a company that actually makes brakes and have put in the r n d. You get more for your money imo.
Pro tip. A GTR is wasting money at its best!
Splimer ran refreshed stock brakes with no trouble at 296 awkw for years.
AP and Alcon seem to be the top teir. Then probably Brembo and the like. Project Mu is well regarded.
If it was my money I would be checking out those Akebonos that Mike posted 355 is a nice size without going overboard.
This is great value imo. Sure it isnt big name brand, but oem gear quality and big.
And inconspicuous.
http://www.conceptzperformance.com/Cart/description.php?II=3217&Car_Type=300&UID=20140720194920203.9.185.243
Would buy this over d2 etc every time
then don't go for cheap shit Pete.
Get a big brake kit like Brembo F50 with 380mm rotors or Alcon or Endless or Project Mu
Oh I also forgot AP and Willwood
and make it worth it
Have you moved completely to xero in house?
nah mate. Setting up a client on cloud with MYOB accoutright live and also fix up their data which back in the stone ages (few entities involved)
Will get the app for them too
And all bank feeds now ready
34 turbo acquired for my highflow, does this look like it's been modified to anyone? I was under the impression the compression wheel on 34's was nylon not steel.
The fins on the turbine look like the stock design and the rear certainly doesn't look milled out. I would say it is as it left the factory.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
