Mugabetown - Whoretownin' At It's Worst.
Heading up to Howells Knob Lookout tomorrow for a picnic with the family. You get some pretty good photos out there on top of the hill with ranges all around.
Another spot I've been keeping an eye on at sunset is Bullocky Rest. If you can drive out to the tip and take shots from Forgan Road over the water you'll get some awesome shots.
sounds very nice
May head out there at dusk but I believe I would lack the lens to take nice shots from forgan road :(
Hey Ants. If you are after 4 cyl and a bit raised check out a subaru xv. I test drove one recently, good to drive, uses bugger all fuel and has a 5 star Ancap rating! Oh and Hi all, tiring day was tiring!
Edited by Bunta
thanks mate
Will check it out
If you can afford to get yourself out there around 5:30 on a weeknight I can bring 2 photographers from work. We work just around the corner. I'm sure they'd be more than happy to go on a little photoshoot adventure!
I may be able to get out after work some time.
Nice shots.
Here's the route I'm taking tomorrow for a picnic. Anyone got any feedback on the route? I've checked the roads on Street View, but the quality of the images doesn't tell me much about how sealed it is in some parts. Want to avoid any loose stuff.
https://mapsengine.google.com/map/edit?mid=zI1PayDARcBQ.kjTgc9FmU-r0
Edited by Simink
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
