Mugabetown - Whoretownin' At It's Worst.
Yup.
I don't like domestic flights let alone the thought of international, the thought of flying overseas makes me nauseous then a few unfortunate events relating to flying overseas just add to that, needless to say, could not fly Malaysian Airlines even if it is just unlucky at what has happened... But I am sure you will have an awesome trip...
We are contemplating USA end of next year, early 2016... Even then I am tempted to stop in Hawaii for a day or two so that it makes the flight a little bit shorter...
Also... Who can suggest some places I can get a custom colour rattle can made up so I can paint some shiz?
Yeah It pretty much cant be bad, no work for 4 months, hard to go wrong really.
Thats probably better, I wouldnt mind doing shorter trips to different places, but Anna is doing courses while we are over there so it sort of has to go that long. I would like to do like 6 weeks there, 6 weeks in europe, 6weeks in South Africa, ect ect. but yeah at the end of the day I have 6 months of leave built up and I can afford to take it half pay so there is plenty of scope for those other things down the track!
Sounds like a plan! I want to do Europe but doing to start with USA/Canada and then another time go and do Europe (mainly Finland and Germany because relatives over there). I want to go to Japan but not sure about anywhere else in Asia or africa etc.
Autobarn
That's what Bodo said, I have no idea if they will be able to get it close to my Metallic pink/purple pearl since it's two colours on my car to make it what it is but if they can get it even remotely close I will be happy...
Martin let me know of a place in Geebung that may be able to do it and I've heard there is somewhere in Strathpine but not sure where. Gives me a few options at least, hopefully one can get close...
Paint matching in a can will never be 100%
Doesn't need to be, just needs to be close so I can cover the white and grey primer until I am ready for a full spray :)
main thing is they need to be able to scan a sample. not just find a paint code
Yeah, I can take my fuel cap off for them to scan otherwise I have a tin at home which is a fairly close match and was used previously on a door handle when my car was broken into.
Japan aw yiiiisssss!!!
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
