Mugabetown - Whoretownin' At It's Worst.
Still under the thumb?
Not really just moved out
Is hks bov plumb back or atmo? If atmo that is one of the reasons there is no rwc. Also many holes were cut to fit the fmic and was the reo cut as well?
and not sure haven't had a chance to have a look at it yet will be doing as soon as I can but if atmo then I'll just re plumb it or change it
http://www.skylinesaustralia.com/forums/topic/439623-brake-clearance-thread/ 375mm rotor, alcon 6 pot caliper behind a 17" TE37
those aren't 8 pot calipers Greg
I already have a switch, thank you very much.
well no point starring at it Pete
Flick it and burn some rubber
No one gonna know
If they do just tell em it's from all that back burning
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
