Mugabetown - Whoretownin' At It's Worst.
Still under the thumb?
Not really just moved out
Is hks bov plumb back or atmo? If atmo that is one of the reasons there is no rwc. Also many holes were cut to fit the fmic and was the reo cut as well?
and not sure haven't had a chance to have a look at it yet will be doing as soon as I can but if atmo then I'll just re plumb it or change it
http://www.skylinesaustralia.com/forums/topic/439623-brake-clearance-thread/ 375mm rotor, alcon 6 pot caliper behind a 17" TE37
those aren't 8 pot calipers Greg
I already have a switch, thank you very much.
well no point starring at it Pete
Flick it and burn some rubber
No one gonna know
If they do just tell em it's from all that back burning
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
