Mugabetown - Whoretownin' At It's Worst.
Yeah it was good fun, was nice to pick up a bat for the first time this year!
I picked up a bat for the first time ever a few weeks ago when we started going, that's why I am so shocking at it!
My folks want to run a car club cruise up to springbrook and wanted to know which lookouts are wheelchair accessible. So i had the arduous task of going up springbrook today. ;)
Also, the national parks people are idiots. Lookout has 2 wheelchair parks, the 500m path to the lookout is wonderful, nice asphalt surface, no steps or anything, but 2 steps onto the lookout platform. Why!?!?!?!
I mean, how hard would it be to make a frikkin ramp.
buy some cement, charge the Sneakey R with some tools,buckets and water solve the problem yourself?
Might just do that..
Here are the steps. All 500m of the path before them perfectly wheelchair/mobility scooter accessible.
Oh and a couple of photos that turned out alright. Should do a SAU cruise with a walk if enough people are interested in being out of the car for more than 10 minutes... Though being SAU i'd be guessing that that isn't going to be many.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
