Mugabetown - Whoretownin' At It's Worst.
Well one of the girls learnt tonight not to piss me off or I can easily sit back and watch them screw things up when the systems go down... Then when they have a lightbulb moment and go oh hey wait a second maybe I shouldn't be a tard I can fix things rather quickly...
Fkn people!!!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
