Mugabetown - Whoretownin' At It's Worst.
that was on Bookface the other day Scottie
I would be very suspicious about the sale and condition of the vehicle.
Seems pretty legit. Contacted the buyer.
He has been left the car in a Will and he lives overseas and wishes to sell it. Car is currently located in a transport & storage Company in South Australia. Once I make payment to this Company they will ship the car to me for inspection where I have 5 days to inspect it and if all it good then its mine. If Im not happy they'll take it back and refund my money.
All I've got to do is log into my internet banking. Back in 10mins....
  • Like 1
Who wouldn't want a deal like that!
That depends on what Chants HRI is Smartie - if only just $50K salary alone and nothing else then I agree.
Ahh yeah well if the total is nudging just over the HECS threshold then that would do it. In which case Chants, try and get deductions etc. to get it down under the threshold! Might be worth talking to Mr. Ants to see what magic he can work. Or one of Pony's dodgy accounting mates.
  • Like 2
Still surprised that everyone actually does know Pony!!! He doesn't lie when he says it!!!
Survey says 535.9rwhp at 21ish psi. Tried more boost but had spark issues. Chucked in a new set of coppers and it got worse and that was the end of tuning. Didnt even get to start bringing timing back in.
Goes hard tho. 2nd gear no longer very useful
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
