Mugabetown - Whoretownin' At It's Worst.
that was on Bookface the other day Scottie
I would be very suspicious about the sale and condition of the vehicle.
Seems pretty legit. Contacted the buyer.
He has been left the car in a Will and he lives overseas and wishes to sell it. Car is currently located in a transport & storage Company in South Australia. Once I make payment to this Company they will ship the car to me for inspection where I have 5 days to inspect it and if all it good then its mine. If Im not happy they'll take it back and refund my money.
All I've got to do is log into my internet banking. Back in 10mins....
  • Like 1
Who wouldn't want a deal like that!
That depends on what Chants HRI is Smartie - if only just $50K salary alone and nothing else then I agree.
Ahh yeah well if the total is nudging just over the HECS threshold then that would do it. In which case Chants, try and get deductions etc. to get it down under the threshold! Might be worth talking to Mr. Ants to see what magic he can work. Or one of Pony's dodgy accounting mates.
  • Like 2
Still surprised that everyone actually does know Pony!!! He doesn't lie when he says it!!!
Survey says 535.9rwhp at 21ish psi. Tried more boost but had spark issues. Chucked in a new set of coppers and it got worse and that was the end of tuning. Didnt even get to start bringing timing back in.
Goes hard tho. 2nd gear no longer very useful
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
