Mugabetown - Whoretownin' At It's Worst.
in morayfield now...still nothing. Death and destruction all round though :)
that Hail was in kilcoy, and I didnt see it again on the way home. But storms this early is never a good thing.....unless you drive a 45 yr old round ball of metal. then who cares!! :) another thing to love about the bug.
Yeah like 2mins of light rain for me and that was all... I'm lucky when at work the car can go under the big shed if there is bad weather and garage at home... Only need to worry if im out when it storms...
That's awesome, now if it could take different trigger inputs and map sensors they would be in business!
waiting for the reply saying it can.........
If it can that would be great, cheap and good!
So it turns out that Matt is working on using the R32 gtr (and S14/S15) boost duty ecu tables to reference the flex fuel tables to be able to adjust boost according to the fuel being used :D
So possible on these 3 ecu's shortly
all still in research phase though
Well, I finally got that corrected group cert from work.
I now owe the gubbermint monies though. I wonder if I can get any deductions... probably time to see an accountANTS.
FYP
  • Like 1
Having different triggering options is probably the most important thing for us Nissan folks, stupid optical 360 degree CAS
think I will need to do something about mine too eventually
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
