Mugabetown - Whoretownin' At It's Worst.
in morayfield now...still nothing. Death and destruction all round though :)
that Hail was in kilcoy, and I didnt see it again on the way home. But storms this early is never a good thing.....unless you drive a 45 yr old round ball of metal. then who cares!! :) another thing to love about the bug.
Yeah like 2mins of light rain for me and that was all... I'm lucky when at work the car can go under the big shed if there is bad weather and garage at home... Only need to worry if im out when it storms...
That's awesome, now if it could take different trigger inputs and map sensors they would be in business!
waiting for the reply saying it can.........
If it can that would be great, cheap and good!
So it turns out that Matt is working on using the R32 gtr (and S14/S15) boost duty ecu tables to reference the flex fuel tables to be able to adjust boost according to the fuel being used :D
So possible on these 3 ecu's shortly
all still in research phase though
Well, I finally got that corrected group cert from work.
I now owe the gubbermint monies though. I wonder if I can get any deductions... probably time to see an accountANTS.
FYP
  • Like 1
Having different triggering options is probably the most important thing for us Nissan folks, stupid optical 360 degree CAS
think I will need to do something about mine too eventually
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
