Mugabetown - Whoretownin' At It's Worst.
early morning work shift. Gotta do stocktake this afternoon too which I'm definitely not looking forward to. Missed Jambo yesterday which I'm not happy about.
Looks like some really good numbers were run. Nitto II being the stand out RB Skyline, one run into the 7's and another at 180mph
Morning all
Yes, Scottie you should have come along I was there, finally got to meet Noel, saw my old boss (Damien Mckern), Nitto II was nutz, had a great day despite being crook
Adams R34 GTR Monster
Nitto II - running a big ass Precision Turbo 7.second GTR
post-5053-14094357218343_thumb.jpgNoel's beauty
Damien's 20B RX3 aka grump2
Was an awesome day out
Great photos Ants. Definitely wish i was there. Yeah Nitto II runs the Promod88 Precision, is the same engine & running gear out of NITTO [R34], then they changed out the 88 sequential box for a powerglide
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
