Mugabetown - Whoretownin' At It's Worst.
Day 1 of our new structure at work, goodbye job satisfaction! *waves*
That bad huh?
My work restructures all the time, in other words everyone else decides to do less and I get even more :dry: And there are only 3 people in the office!!!
Yeah they split our functions into 2 teams. Assessment and compliance. We used to do both and it was good for our careers, have really well rounded skills. Now you are either glued to a desk or dealing with dumb complaints all the time.
so, you should now say that you 'specialize' in either Assessment / compliance Andy
That's a possibility I guess. Being overly specialised in my field isn't always a good thing though!
that is true.
However, you know that you can and have been working with both components up to now.
just don't forget that
Also spotted a white Stag with an R34 front end conversion, had a GTR badge on the grille but I didn't see if it was a GTR front end. Pulling onto Samford road on the range between Samford and Ferny Grove.
Why is everyone putting spotted posts in whoretown?
This offends me :P
I didn't rrealiseit was whoretown till you said that...I just saw Mike's post and assumed it was the spotted thread.
standard 34 front does not fit, needs the GT-R front to fit the wide track
seeing as this is now the spotted thread, saw PEte today heading gold coast bound on the M1 in the GT-R, gave him a toot as he drove past me doing 120 and didnt even get a response !
Slacker
Slacker
What a rude prick...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
