Mugabetown - Whoretownin' At It's Worst.
Morning! Everyone ready for the drag day?
I'm excited! Car is mostly ready. Have new denso plugs and splitfire coilpacks to go in if I get motivated. Only other thing to do is to make sure the MT's are ready!
who gives a shit when you can say "I run 20 pound of boost" aint nobody gonna mess with you when they hear that ;)
I'll say 'I run infinity boostz!' that will get the bishes wet :yes:
  • Like 1
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
