Mugabetown - Whoretownin' At It's Worst.
you do realise that he's engaged now?
If not, Connie has some competition
pfft connie aint got shit on me. I got an awesome gtr and like over 100 model cars of skylines and what dies she have to offer? I mean sure she has boobs and a vjayjay (well I assume she does :P) but that shit gets you into trouble
  • Like 1
She lets me rev her over 4k tho :P
Morning all :)
Getting the beast tuned tomz @ Godzilla - so damn excited.
Haven't driven much for the past 5 months due to the last tuner giving me 100km to a full tank (off boost) ...... 0.o
noice
Yep, so far McFly is my favorite Bish.
That doesn't surprise me, I know how protective you are of him :P
Ohhh that's tempting...
Calm down Mike, don't give in so easily! You can totally negotiate for more than that... ;)
Yeah, but V-TEC doesn't kick in till 9k so hes got a while to go before he gets any
Any photographers among us? Want some pics of the zed taken for submission to the aus300zx calendar before 2nd Nov.
Wannabe's who work for free (or work for rides) prefered ;) Credit in the calendar provided.
I'm calm...but Chris is offering to let me take his GTR into uncharted territory...it's likely to spin a big end due to the surprise of actually being driven :P
By V-TEC do you mean spun big end because 32?
I'm a wannabe photographer, check out the shit I post after events to see what I can and can't do. What sort of location were you thinking?
I have seen the photos from Martins Phone, top quality sexts.
This is true, he is a top notch sexter.
  • Like 1
Have a look as these than Mike, http://s962.photobucket.com/user/cadmoon/library/August%20Cruise%20and%20BBQ
Morning/evening/overcast days are best for car photos.
I'll be taking a few shots of that.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
