Mugabetown - Whoretownin' At It's Worst.
Well the zed is nearly completely back together. Exhaust back on and everything connected. Runs on 6 and can move under it's own power.
Had to relocate the windscreen washer to the boot for airflow through drivers side side mount intercooler. Didn't have enough vac hose at home to run the plumbing but I did run all the electrics for it.
All that is left now is obviously the plumbing for the washer bottle, all the undertrays, and the intercooler ducting which is a royal PITA. Going to leave that until the tech day on sat.
Oh and I need a new wideband sensor. the one I installed is stuffed, reading 3points leaner than the other. Not 3/10th, 3 wholes.
So I was forced to replace my muffler today due to a severe rattle, my car now actually has an exhaust sound.
Picked this up second hand for $100 fully installed inc welding. It's a name brand muffler, but let's just call it a 'legnaflow'...
Awesome sauce! A step closer to skids... er... I mean Milton Maccas runs....
Sweet Baby Jesus. Looks the business.
Also, Blog update mother bitches!
http://tx5turbo.blogspot.com.au
Morning everyone!
Just a quick pop in to say hi and to let everyone know that the club emails should be working later today.
Unfortunately cmshosting and puntoitalia just flipped the switch and deleted our hosting from their servers without notification or warning.
The hosting has now been moved to a new web host and a blog/news portal with information on what events are coming up etc as well as links into these forums will be setup.
At present, any communication should be directed to [email protected]
All of the @sauqld.com email addresses should be functional later today.
Chat soon. Bout time I turn up to an event and catch up with everyone.
Cheers,
Ben.
I dislike pickles... But ham and cheese are tasty...
I followed lunch up with some popping candy and the accounts girl laughed at me :)
Now I REALLLLLY want milk but I don't have any of my milk at work :(
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
