Mugabetown - Whoretownin' At It's Worst.
yeah hanging in there. not allowed to work at the moment. still sorting out some health issues. too much partying when your young takes its toll.
still haven't got a Nissan and just about to acquire a third BMW. I also have my eyes on an E30 coupe which I plan to convert to an SR20DET for a track car. Will see how it goes financially over Christmas.
whoa. That sounds pretty heavy Benno.
Take good care of yourself mate
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
