Mugabetown - Whoretownin' At It's Worst.
Eagle Rods,
ARP rod fastener kit.
ARP head & main stud kit.
Wiseco 0.20? o/size forged pistons & Molly rings.
Balanced crank Nissan bearings
Heads reconditioned O/S valves, with 3 angle valve work
JWT 500R cams, [ 2013 ]
New Hyd lifters, [2013]
New HD vtc springs [2013]
New Nissan timing belt + pullies [2013]
Turbos Garrett GT2871R.
AMS MaxFlow cast ion manifolds
New oil / water lines, hoses.
HKS blow off valves.
3? dumps & exhaust system from turbos back.
53mm Alum radiator.
1250lb clutch balanced with fly wheel. [H/D].
Under drive pulley.
Apexi AVC-R Elect boost controller.
Nistune ecu.
New coil packs & plugs.
New Injector plugs.
New 02 sensors.
Short throw manual shift. [stillen]
One piece tail shaft new unies, Tail shaft loop.
New gear box & engine mounts.
New 550hp Wilbro fuel pump, filter,
New Nissan AFM unit.
Stillen large SMI.
800CC Sard injectors + pressure reg.
New brake master cylinder.
New clutch slave cylinder & hose.
Apexi pod air filter.
HID low beam lights.
New air compressor & condenser.
Re Upholster interior and seats.
98+ spec manual gear box [ 2012 ]
Exedy 5 puck HD button clutch. [ 2012 ]
Kyb adjustable shocks front and rear with eibach springs
r34 GTT 310mm front brakes
Adjustable front camber [super-Pro]
New bearings in Alternator.
New Nissan water pump
4 Point harness drivers seat only
Aparantly made 469rwhp @ 18psi previously in WA, but I don't trust the guy who did that tune. Has gone 11.59@120. PLENTY more in it if you so desired to get those turbos into the meat of them.
Edited by MagicMikeZ32
Yep. Inside and out it is very clean. Except the wheels, I'd change them to something jap. It's got some Koya's or something on it now. 275 rubber up the back tho.
I would buy it myself if I didn't already have 2.5 in the shed, and I knew what was going to happen with my job after september...
Gday Antz! yea mate going well now working away.
Yea things kinda grinded to a halt when I got made redundant, was out of work about 12 months so car just sat collecting dust. took it out a few times but cant race it hard until I replace the PFC and fit a custom crank trigger. Else the cars going strong.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
