sneakey pete Posted June 9, 2015 Share Posted June 9, 2015 I'll take $50 to dispose of it for you. Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7547557 Share on other sites More sharing options...
MagicMikeZ32 Posted June 9, 2015 Share Posted June 9, 2015 Sell that stupid 34 Michael and buy it. Will save you a fortune, and be faster. $10K. Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7547561 Share on other sites More sharing options...
Ants Posted June 9, 2015 Share Posted June 9, 2015 Sell that stupid 34 Michael and buy it. Will save you a fortune, and be faster. $10K.but engine out job Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7547830 Share on other sites More sharing options...
Smity42 Posted June 9, 2015 Share Posted June 9, 2015 Really 10k? What's the catch? Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7547831 Share on other sites More sharing options...
Ants Posted June 9, 2015 Share Posted June 9, 2015 Really 10k? What's the catch? VG30 that's the catch 1 Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7547836 Share on other sites More sharing options...
MagicMikeZ32 Posted June 9, 2015 Share Posted June 9, 2015 No catch. There is a bike for sale that he wants to buy instead. And no engine out required. Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7547851 Share on other sites More sharing options...
MagicMikeZ32 Posted June 9, 2015 Share Posted June 9, 2015 (edited) Eagle Rods,ARP rod fastener kit.ARP head & main stud kit.Wiseco 0.20? o/size forged pistons & Molly rings.Balanced crank Nissan bearingsHeads reconditioned O/S valves, with 3 angle valve workJWT 500R cams, [ 2013 ]New Hyd lifters, [2013]New HD vtc springs [2013]New Nissan timing belt + pullies [2013]Turbos Garrett GT2871R.AMS MaxFlow cast ion manifoldsNew oil / water lines, hoses.HKS blow off valves.3? dumps & exhaust system from turbos back.53mm Alum radiator.1250lb clutch balanced with fly wheel. [H/D].Under drive pulley.Apexi AVC-R Elect boost controller.Nistune ecu.New coil packs & plugs.New Injector plugs.New 02 sensors.Short throw manual shift. [stillen]One piece tail shaft new unies, Tail shaft loop.New gear box & engine mounts.New 550hp Wilbro fuel pump, filter,New Nissan AFM unit.Stillen large SMI.800CC Sard injectors + pressure reg.New brake master cylinder.New clutch slave cylinder & hose.Apexi pod air filter.HID low beam lights.New air compressor & condenser.Re Upholster interior and seats.98+ spec manual gear box [ 2012 ]Exedy 5 puck HD button clutch. [ 2012 ]Kyb adjustable shocks front and rear with eibach springs r34 GTT 310mm front brakesAdjustable front camber [super-Pro]New bearings in Alternator.New Nissan water pump4 Point harness drivers seat only Aparantly made 469rwhp @ 18psi previously in WA, but I don't trust the guy who did that tune. Has gone 11.59@120. PLENTY more in it if you so desired to get those turbos into the meat of them. Edited June 9, 2015 by MagicMikeZ32 Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7547852 Share on other sites More sharing options...
boiracer Posted June 10, 2015 Share Posted June 10, 2015 morning all That is an impressive shopping list, if I had the 10k I would almost consider it. Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7548433 Share on other sites More sharing options...
MagicMikeZ32 Posted June 10, 2015 Share Posted June 10, 2015 Yep. Inside and out it is very clean. Except the wheels, I'd change them to something jap. It's got some Koya's or something on it now. 275 rubber up the back tho. I would buy it myself if I didn't already have 2.5 in the shed, and I knew what was going to happen with my job after september... Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7548457 Share on other sites More sharing options...
SilverECR33 Posted June 10, 2015 Share Posted June 10, 2015 loaded this page for the first time in years! sau still tickin along I see. Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7548493 Share on other sites More sharing options...
Ants Posted June 11, 2015 Share Posted June 11, 2015 loaded this page for the first time in years! sau still tickin along I see. very slowly Dale. I havent seen you since last drag battle. Hows things? Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7548494 Share on other sites More sharing options...
MagicMikeZ32 Posted June 11, 2015 Share Posted June 11, 2015 loaded this page for the first time in years! sau still tickin along I see. Hey mate! Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7548508 Share on other sites More sharing options...
SilverECR33 Posted June 11, 2015 Share Posted June 11, 2015 Gday Antz! yea mate going well now working away. Yea things kinda grinded to a halt when I got made redundant, was out of work about 12 months so car just sat collecting dust. took it out a few times but cant race it hard until I replace the PFC and fit a custom crank trigger. Else the cars going strong. Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7548575 Share on other sites More sharing options...
SilverECR33 Posted June 11, 2015 Share Posted June 11, 2015 Mike! hey man, just trying to figure out these quote buttons shits not working like it used to! we should catch up soon, have you seen Ians new pad yet? Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7548576 Share on other sites More sharing options...
MagicMikeZ32 Posted June 11, 2015 Share Posted June 11, 2015 Nah haven't seen it, never get an invite lol (mostly because I find it hard to actually get to events these days) lol Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7548599 Share on other sites More sharing options...
skins Posted June 11, 2015 Share Posted June 11, 2015 WANT!!!! http://www.vocativ.com/tech/machines/coming-soon-your-very-own-flamethrower-for/ Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7548642 Share on other sites More sharing options...
Cadmoon Posted June 11, 2015 Share Posted June 11, 2015 WANT!!!! http://www.vocativ.com/tech/machines/coming-soon-your-very-own-flamethrower-for/ I want this so much, so so much. It's the best way to fix Nick's car. Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7548693 Share on other sites More sharing options...
Ants Posted June 11, 2015 Share Posted June 11, 2015 Moaning Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7548990 Share on other sites More sharing options...
Cadmoon Posted June 12, 2015 Share Posted June 12, 2015 Evening Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7549332 Share on other sites More sharing options...
MagicMikeZ32 Posted June 14, 2015 Share Posted June 14, 2015 sup bishes Link to comment https://www.sau.com.au/forums/topic/431233-mugabetown-whoretownin-at-its-worst/page/1187/#findComment-7550454 Share on other sites More sharing options...
