Mugabetown - Whoretownin' At It's Worst.
Eagle Rods,
ARP rod fastener kit.
ARP head & main stud kit.
Wiseco 0.20? o/size forged pistons & Molly rings.
Balanced crank Nissan bearings
Heads reconditioned O/S valves, with 3 angle valve work
JWT 500R cams, [ 2013 ]
New Hyd lifters, [2013]
New HD vtc springs [2013]
New Nissan timing belt + pullies [2013]
Turbos Garrett GT2871R.
AMS MaxFlow cast ion manifolds
New oil / water lines, hoses.
HKS blow off valves.
3? dumps & exhaust system from turbos back.
53mm Alum radiator.
1250lb clutch balanced with fly wheel. [H/D].
Under drive pulley.
Apexi AVC-R Elect boost controller.
Nistune ecu.
New coil packs & plugs.
New Injector plugs.
New 02 sensors.
Short throw manual shift. [stillen]
One piece tail shaft new unies, Tail shaft loop.
New gear box & engine mounts.
New 550hp Wilbro fuel pump, filter,
New Nissan AFM unit.
Stillen large SMI.
800CC Sard injectors + pressure reg.
New brake master cylinder.
New clutch slave cylinder & hose.
Apexi pod air filter.
HID low beam lights.
New air compressor & condenser.
Re Upholster interior and seats.
98+ spec manual gear box [ 2012 ]
Exedy 5 puck HD button clutch. [ 2012 ]
Kyb adjustable shocks front and rear with eibach springs
r34 GTT 310mm front brakes
Adjustable front camber [super-Pro]
New bearings in Alternator.
New Nissan water pump
4 Point harness drivers seat only
Aparantly made 469rwhp @ 18psi previously in WA, but I don't trust the guy who did that tune. Has gone 11.59@120. PLENTY more in it if you so desired to get those turbos into the meat of them.
Edited by MagicMikeZ32
Yep. Inside and out it is very clean. Except the wheels, I'd change them to something jap. It's got some Koya's or something on it now. 275 rubber up the back tho.
I would buy it myself if I didn't already have 2.5 in the shed, and I knew what was going to happen with my job after september...
Gday Antz! yea mate going well now working away.
Yea things kinda grinded to a halt when I got made redundant, was out of work about 12 months so car just sat collecting dust. took it out a few times but cant race it hard until I replace the PFC and fit a custom crank trigger. Else the cars going strong.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
