Mugabetown - Whoretownin' At It's Worst.
Well its still something one needs to pay when buying brake kits from overseas.
Also, Akebono's don't fit. Dam.
Now i'm really intrigued about those Autech brakes. AP racing 6 piston kit with the same size rotor fits under my car, the rotor on the Akebono's is just too chunky. So its possible that these Autechs would fit. What isn't possible is finding the dam specs of them though
only for items costing $1,000 (inc. postage) unless tobacco or alchohol
and its customs duty then 10% GST on any imported good declared at >$1,000
Autechs are huge - and I bet they wont fit your 17inch te37's
have you seen Fatz brake sale thread?
http://www.skylinesaustralia.com/forums/topic/434418-fatz-big-brake-sale-grex-ap-racing-brembo-stoptech/
Well, good luck finding a brake kit for under $1000!
And for customs duty, what's involved there? never dealt with large overseas purchases before.
Just checked, can fit Alcon 365mm 6 piston kits. TE37's are awesome.
Why don't the Akebonos fit?
The caliper is to tall, the total diameter including caliper is greater than the internal void on the wheels.
Which surprises me, as as mentioned above i can fit 365mm kits and not the 355mm akebonos.
I see. I see
Buy the fronts in this thread ;)
http://www.aus300zx.com/forum/showthread.php?t=329553
Rears are cheap minus rotors/pads
Edited by MagicMikeZ32
Would require dumping 4K on new wheels first...
Heck I cold just buy another skyline or 2 instead of trying to get those brakes to fit!
Edit: picture of 3 different brakes.
As you can see the Akebono's (red) stick out about 10mm more per side than the AP's (black) with the same size rotors. The 365mm Alcons (blue) are in the middle but have a better profile which seems to match the TE37's slightly better (they also curve in towards the front). I'd have to take it off again to check but from memory it's actually the tip of the middle hump that clashes with the Akebonos, not the top hump.
^^^ spot the engineer
:P
I thought he just liked drawing pictures :P
I would have looked and gone ehh doesn't fit, new wheels needed... :D
The Akebonos are chunky as fuark calipers. If you actually see them, they're larger than life. Much like my... any way.
With puchasing from o/s. You pay the cost of the goods + shipping to supplier ($x). Pay 2.5% import duty (1.0025.$x = $y) then you pay GST on that sum so 1.1x$y
Ants would probably need to correct me on import duty value.
Just checking in all, I'm
Not actually dead haha
Still under the thumb?
http://www.skylinesaustralia.com/forums/topic/439623-brake-clearance-thread/ 375mm rotor, alcon 6 pot caliper behind a 17" TE37
What would one say if they were looking for a 33 gtst and it was for sale for 3700 with fmic hks blow off, no rego or Rwc
Is hks bov plumb back or atmo? If atmo that is one of the reasons there is no rwc. Also many holes were cut to fit the fmic and was the reo cut as well?
Cricket bat... Your cricket bat is rather large...
  • Like 1
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
