Mugabetown - Whoretownin' At It's Worst.
Tony you are being completely disingenuous to yourself lol
I'm not clever. There are areas that I excel in and areas that I struggle in. This makes me selfaware, and a douche from time to time, but not clever.
There are cleverer people than me out there and I'm aware of this.
Eg: Bunta is better at maintaining a relationship than I (as history has proven)
Ants is better at avoiding ATO Audits
McFly is a far superior driver
MagicMike is a far superior driver and is far more patient than I
Nick is far superior at being an idiot than I.
You are selling yourself short lol
I see the point you are making, but a qualified opinion is better than an unqualified one. Like ppl who cite others as their source of authority on mechanical subjects :)
dont have to be smart to get a qualification
I see the point you are making, but a qualified opinion is better than an unqualified one. Like ppl who cite others as there source of authority on mechanical subjects :)
as above...
throw your paper around all you like..
if you want to start a pissing fight i have 3 qualification in 3 different fields
I know that there's some 80 year old guy in England who has about 12 different degrees, and even a few doctorates in those fiels. Obviously he has the superior knowledge of RB engines!
Andy: is what your setup is/will be basically a toothed gear stuck onto the end where the CAS was with an optical sensor measuring the teeth to get RPM and sending it back to the ECU?
is this also what the other setup is?
  • Like 1
So using your thought process, wouldn't an opinion from a qualified source be more plausible than an opinion from a less qualified source?
And what subjectivity is offered to the comparisons of level of qualification? Is it proven academic results, real life results etc?
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
